leaking oil
  • 1572 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
leaking oil
« on: July 01, 2004, 03:21:48 AM »
I am leaking oil.  I think it's coming from around the distributor of my new Sammy.  Is there a seal or is it just RTV?  I really appreciate the help.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline Cwkick
  • 888
Re: leaking oil
« Reply #1 on: July 01, 2004, 03:36:01 AM »
There is an o-ring around the distributor that should be replaced or resealed.
Cwkick
Offline supazuk
  • git 'er done!
Re: leaking oil
« Reply #2 on: July 01, 2004, 03:45:47 AM »
Not to hyjack the tread but has any one else brocken more then one touqes bit trying to loosen that distributer  hold down bolt????
shut up and wheel it.. sick of hearing oh my (fill in blank) stock can climb mountians yet the only off roading its seen is the curb their g/f ran over!
Offline TomKat
  • 211
Re: leaking oil
« Reply #3 on: July 01, 2004, 04:59:51 AM »
Yeah, I don't even try to break 'em loose with the torx bit anymore. I take a cold chisel to the edge of the bolt and use that and a hammer tap to break it loose, then use the torx bit to remove it. I put a regular hex bolt in place of them always.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Kreg
  • 795
    • Island 4x4
Re: leaking oil
« Reply #4 on: July 01, 2004, 05:08:06 AM »
Ya I had the same problem. It was the O-ring.
Offline brace
  • 264
Re: leaking oil
« Reply #5 on: July 01, 2004, 09:06:51 AM »
I went to my trusted local mechanic, and he said it was coming from the oil filler cap because I am not getting any vacuum pressure.  Also, there is a pin hole leak on the bottom of the oil pan.  A bolt in the right hose and some jb weld and I should be good.  Let you know in a half and hour.
Offline brace
  • 264
Re: leaking oil
« Reply #6 on: July 01, 2004, 09:52:36 AM »
Nothing like waiting for something to dry.  I can't wait to add oil and not leak.
Offline idaholwb
  • 772
Re: leaking oil
« Reply #7 on: July 01, 2004, 06:59:21 PM »
 Just go to www.trailtough.com and order the stupid o-ring. And I've never heard of a pinhole leak in a Suzuki oilpan. It's more than likely the o-ring. They are cheap, if you were in my neck of the woods I'd sell you one, but you don't...sorry.
97 Sport
265/70-16s
2" lift
2.0 swap
