Talk to HAWK made my mind on my motor
  • 15 Replies
  • 2756 Views
Re: Talk to HAWK made my mind on my motor
« Reply #15 on: July 01, 2004, 07:37:05 PM »
.020  cause a timing problem, I don't think so,
you could turn the cam 1 tooth and you would
hardly feel any if any difference.
On a different note, I got the head off the 16V
motor and the Combustion Chamber is smaller
than the 8V motor, by about 5 cc, so the compression
will be higher with the 16V head, than with the 8V,
so pistons need to be modified to lower the CR with
a 16V head.
The block on the 1.3 motor is also about 1 1/8" shorter
than the 1.6 motor, so a 1.6 engine is a tighter fit in the
Sammy.
