Talk to HAWK made my mind on my motor
  • 15 Replies
  • 2758 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: June 28, 2004, 01:48:40 PM »
Ok here is my plan
take the stock 1.6 8valve out
Bore it .050mm over new pistons and rings and bearings  and all new seals oil pump.
The head do a mild port and polish 3 angle valve job.
.20th off the head to raise the comp. Hawks cam or the calmini not sure yet. Rocky road cam gear and crank pulley.
The throtle body took it apart my guy that ports all the parts for my turbod honda is going to bore it out  4mm. The boss around the injector will be ported out alot to flow more air. Also thinking of spacing the housing say 1/4" for better fuel addimisation.
Ingniton some better wires MSD 8.8 and CRANE coil.
I have a header exhaust and a snorkel on order. Im going to drive it for 1000km then go strap it on the local dyno and do some fuel addjustments via fuel pressure also see if i can move the power band around with the cam gear.
i dunno ill post a whole write up on it and also alot of dyno graphs
01 GRAND VITARA
Offline jerryp58
  • 449
Re: Talk to HAWK made my mind on my motor
« Reply #1 on: June 28, 2004, 11:37:24 PM »
Sounds like fun times ahead.  I'll be looking forward to progress reports :)
Jerry
Offline Speedracer7c
  • 2210
« Reply #2 on: June 29, 2004, 12:01:02 AM »
I think we all will
Offline JDMCRX
  • 1110
« Reply #3 on: June 29, 2004, 02:10:48 AM »
Im going to start the project hopefully in 2 -3 weeks after i make my 300whp with my honda.
Im going to see for 100whp cause i know right now it probly makes around 65-70 whp now lol
01 GRAND VITARA
Offline 1bigtracker
  • 3409
« Reply #4 on: June 29, 2004, 03:55:00 AM »
don't forget a timing cover with that cool peace that comes out to play with the cam sprocket.
stu
Offline JDMCRX
  • 1110
« Reply #5 on: June 29, 2004, 04:47:05 AM »
The timing cover i have now is junk im going to cut it open for the dyno then get a new one for the street and trails
01 GRAND VITARA
« Reply #6 on: June 29, 2004, 07:32:54 AM »
300 RWHP in a Honda, heavy task, and only
if you turbo it, problem is that much HP is too
race like, street driving that kind of motor will
kinda suck, unless you really like shifting and
racing on the street.
See http://www.toyotaperformance.com/400_hp.htm
and read up some about high output
street engines, you might change your
goal to a more drivable combination, unless
of coarse you are building a Honda racer
then by all means, build away
« Last Edit: June 29, 2004, 07:35:49 AM by wildgoody »
Offline JDMCRX
  • 1110
« Reply #7 on: June 29, 2004, 07:44:33 AM »
My honda D16Y8 made 265 at 12psi street driven not one prob yet just waiting for my 880cc injectors.
The sidekick i was going to turbo but i want reliable truck. ;D
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #8 on: June 29, 2004, 07:46:19 AM »
Here is my build up let me know what u guys think. all work and tunning done by urs truely
http://www.honda-tech.com/zerothread?id=906315
01 GRAND VITARA
« Reply #9 on: June 29, 2004, 11:56:51 AM »
Nice buildup pics, I wonder about your 9.5
CR, little high, unless you lowered the CR
and just used the 9.5 Weisco pistons, I
would say you did a fair bit more than the
Turbo Kick build, I'm all stock exept the
SS Exhaust Valves and a Cam, I find ping
a little troublesome on 87 fuel, what do you
use to prevent ping at 12 boost, Water injection
or high Octane gas ??
I have to say also the article was targeted at
a 400 HP Honda, not 300, I though you might
be able to use some info found there to help
you obtaine your 300 goal and keep that motor
alive in the process.
Point of interest is the GMC Syclone that boosted
to 15 PSI used a CR of 8.35:1      I want to go to
some low CR pistons like 7.5 or 8 to 1 CR and pump
the boost to 12-14 and see what I can get from a Kick
Motor.
I also noticed you are running a 16V head, much better
for the flow, plus it's ported for increased flow.
My What a big Turbo you have  :o
Offline JDMCRX
  • 1110
« Reply #10 on: June 29, 2004, 12:24:39 PM »
Thanks man
Im using 91 octane u just have to tune the ingition timing conservitve. I never  gat any detination.
When u tune start with less timing then work ur way up another thing is colder plugs help alot for missfires.
Yeah the car is fast ran my friends Modded Z06 from a 100km roll and at 210km he was 2 cars ahead.
01 GRAND VITARA
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #11 on: June 30, 2004, 04:10:38 AM »
Nice civic .Very clean. Makes me miss my MR2  :'(
Offline JDMCRX
  • 1110
« Reply #12 on: June 30, 2004, 04:39:07 AM »
Its actualy a 2000 acura 1.6el
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #13 on: June 30, 2004, 04:40:12 AM »
Thanks tho
Im debating now which cam to use Hawk said there cam is better for low end torque and the Calmini is good for midrange i dunno what i want.
01 GRAND VITARA
Offline 90Stomper
  • 427
« Reply #14 on: July 01, 2004, 01:25:27 PM »
when i did all my stuff i was ganna do this too, but my guy told me there would be no big advantage and that because the of the way the crank and cam pullies are right over each other it could cause timing problems...? :-/
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
