toy front driveline in rear of sammy
  • 1514 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« on: June 16, 2010, 10:13:11 PM »
i was thinking about using a Toyota front drive line in the rear of my samurai has anyone done this i know the flanges are different
« Last Edit: June 19, 2010, 06:11:15 PM by fordguy79 »
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: toy front driveline in rear of sammy
« Reply #1 on: June 19, 2010, 09:21:09 PM »
i know it needs shortend but i think it will work
Offline MadMaxZuki
  • 77
« Reply #2 on: June 20, 2010, 01:57:46 PM »
i am going to be doing that to my rig except my rear shaft is a Sammy front.I am not 100% but i am pretty sure the hubs wont each other on top of the flanges having to be re-drilled. Rock 4x makes bolt on adapters (https://www.rock4xfabrication.com/store/product_info.php?cPath=21_39&products_id=78&osCsid=6bd1fbe01bc6e04d29c63077dd55261a) , Low Range sells them too http://www.lowrangeoffroad.com/index.php/suzuki/samurai/drivelines-spacers/toyota-drive-line-adapters.html
And you will need to shorten the drive shaft and get it balanced. If these things are truely bolt on then you can keep your stock as a spare.
« Last Edit: June 20, 2010, 02:37:37 PM by MadMaxZuki »
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Offline Amilla
  • 1076
« Reply #3 on: June 21, 2010, 01:31:57 PM »
Its going to be to long and the holes dont match up.  I found it to be pretty easy to re-drill the flange, an adapter will work just fine also.
79-85 are the best year shafts to get.
The later years will work but the operation angle of the CV will be less.
Amilla
