Problem Solved!!!
  • 10 Replies
  • 1954 Views
Offline Speedracer7c
  • 2210
Problem Solved!!!
« on: July 03, 2004, 02:57:06 AM »
I am happy to say that my tracker issues are now solved! As per wilds info I checked the ignition timing, it was supposed to be between 4-6 degrees and was at pretty much zero, I think that is because when i went to loosen the disty bolt the thing was pretty loose and I think it just worked it self out. Well that is the best news today and let me tell you this thing has more power than it has ever had! Woo hoo!!!
Re: Problem Solved!!!
« Reply #1 on: July 03, 2004, 04:05:31 AM »
Great to hear it was nothing major. Did you get out and try the new goodies yet?
Offline paps133
  • 166
  • make your own road..
« Reply #2 on: July 03, 2004, 05:09:08 AM »
Thats good news. i knew it was your timming, as posted before.  hopefully you didn't spend to much on useless stuff that you didn't need. If you did at least you'll have it when they don't work. pierre
  • 2210
« Reply #3 on: July 03, 2004, 05:20:45 AM »
A little bit not much, let me tell you though it was a real suprise how well it did offroad
« Reply #4 on: July 03, 2004, 05:35:39 AM »
Hey, glad to hear your back on the road  :)
Set your advance to 10* .
You can go more also like 11* or 12*
if you don't have any pinging problems,
it will run better yet  ;)
Offline Mike71
  • 1449
« Reply #5 on: July 03, 2004, 06:46:45 AM »
how do u set timing..and what is adanvce??
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #6 on: July 03, 2004, 09:27:29 AM »
Timing is measured in crankshaft degrees before the piston reaches top dead center. If you advance it, the plugs spark before TDC, if you retard it, they spark after TDC.
Offline 1bigtracker
  • 3409
« Reply #7 on: July 03, 2004, 09:36:14 AM »
Great!  glad to hear it is running.  thought it had somthing to do with it being in winooski all day last sat, but i guess not. ;D  and are you up for an over night run in a few weeks in VT?
stu
Offline Mike71
  • 1449
« Reply #8 on: July 03, 2004, 10:35:30 AM »
so how do i check/modify this?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #9 on: July 03, 2004, 10:59:48 AM »
Timing light
  • 2210
« Reply #10 on: July 03, 2004, 05:09:18 PM »
stu
Sure when is it.
