time to build
  • 1149 Views
Offline gotzuk?
  • 18
time to build
« on: June 06, 2010, 03:51:45 PM »
alright guys i need some help. Ive got a 1994 samurai with 3 inch body lift and 2 inch shackle lift. 31" tires and other than that its stock. Ive got $2000 to work with and i want to spend in wisely. Id like to do a yota axle swap and transfer case. Also a winch would be nice. Whats makes the transfer case out of a yota so much better than the stock sammi? thanks
Re: time to build
« Reply #1 on: June 07, 2010, 10:30:19 AM »
It's generally considered to be stronger.  The problem with swapping it into the Sammy though is you loose your high range reduction.  So you will have a much harder time turning the larger tires.
