Superwinch 3500 terra 35 winch on X-90 ?
  • 14 Replies
  • 4235 Views
Offline drenalin
« on: June 04, 2010, 05:28:29 PM »
 I was thinking on trying the terra 35 superwinch 3500 lb from princess auto on front of my x-90 , does anyone have any experience with this winch ?  Not sure if it will have enough balls for my x-90.
Re: Superwinch 3500 terra 35 winch on X-90 ?
« Reply #1 on: June 05, 2010, 10:11:00 AM »
It will work to pull you forward, but a 6000+ is recommended.  You usually want to go at least 1.5 time the weight of the vehicle you want to tow.  I prefer at least 2x.
With the low cost of 8000lb winches that work well enough for light use it's usually worth it to jump up to the stronger winches, even if they don't pull as fast.
Offline drenalin
« Reply #2 on: June 05, 2010, 10:36:48 AM »
Thanks, the 3500 is 389.00 can , do you know of a good 6000 lb range winch close to that price ?
Offline camokick93
  • 47
  • SUPPORT OUR TROOPS
« Reply #3 on: June 05, 2010, 02:30:00 PM »
Hi there,you can get a 8500lbs superwinch at Canadian tire for 399.99$.
Simon, Montreal.
93 4door sidekick,5spd,3in calmini,ome frt coils with 2in spacers,calmini winch bumper,8500 superwinch,calmini front skid,custom rock slidders,custom belly pan,frt ome shocks with upper mount flip,4.24 t-case gears,truck painted camo,hence my user name.I have rear ARB,calmini header exh. combo to be installed soon.FOUR DOORS KICKASS
Offline drenalin
« Reply #4 on: June 05, 2010, 02:51:11 PM »
Thanks...i'll look into that.
« Reply #5 on: June 06, 2010, 01:32:18 AM »
Do you have a Harbor Freight up there?  You can sometimes get the Chicago Electric winch for around 300, should be similar pricing up north.  Not the fastest in the world and you should probably pull the motor apart every few years to clean it out, quicker if you like to dunk it under the water, but they work and will get you out of a jam.
Offline tombstone
  • 212
« Reply #6 on: June 07, 2010, 07:34:18 PM »
Hope you know what will happen when you add that 75lb winch to the nose of a X90!! :o
Offline ToyYoda
  • 226
« Reply #7 on: June 07, 2010, 10:40:51 PM »
Same thing that will happen to a Sidekick !
« Reply #8 on: June 08, 2010, 10:42:57 AM »
Hilarity?
Offline drenalin
« Reply #9 on: June 08, 2010, 07:14:51 PM »
I accually want to add weight to the front , the calmini front suspension seems a bit stiff , they even tell you in the calmini guide that the kit is built for equiped vehicles with heavy bumpers, winch ect. The x-90 is a very light rig, i think it could use xtra weight on that beefed up suspension.
Offline lv2fsh
  • 312
  • 19
« Reply #10 on: June 08, 2010, 07:52:50 PM »
I got a 6000# Vortec on Ebay for about $240.00 US shipped. The weight difference between 6000# and the 8000# is about double . Like 43 lbs vs 90+. Not the fastest but hasn't failed me yet. For tough stuff, I have a snatch block and a 100ft synthetic rope rated at 19000#
Offline camokick93
  • 47
« Reply #11 on: June 08, 2010, 08:17:07 PM »
Here's mine,with ome 962 coils no sagg.
Offline camokick93
  • 47
« Reply #12 on: June 08, 2010, 08:24:59 PM »
With a better picture.
Offline camokick93
  • 47
« Reply #13 on: June 08, 2010, 08:26:11 PM »
Oops wrong pic.be back in a second.
Offline camokick93
  • 47
« Reply #14 on: June 08, 2010, 08:28:51 PM »
there we go.
