Rear Axle Bearing
  • 1242 Views
Offline JayInBarrie
  • 107
Rear Axle Bearing
« on: June 02, 2010, 04:53:02 PM »
One of my rear bearing have started to go.
Was thinking of being lazy and pulling a whole axle from the wreckers.  Just want to make sure what axle I can use for a '99 Tracker.
All Sidekick/Trackers are to short right?
XL-7 have the a different spline count and are to thick.
So Tracker/Vitara/GV from '99 and up...Right.
I need a few other parts from the wreckers, so this seems a easier fix then putting on new bearings (assuming that I can find one with good bearings  ;D)
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
Offline Novadon
  • 205
  • South Carolina. USA
Re: Rear Axle Bearing
« Reply #1 on: June 02, 2010, 06:15:52 PM »
That's too much work for a relatively easy bearing replacement need.  ;)
See...
http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/19396-has-ne1-here-pulled-rear-axle.html
And what if the junker rear is toast?  :o
03' Honda Odyssey
Offline Frank84
  • 176
« Reply #2 on: June 02, 2010, 06:58:32 PM »
Great info in that link - thanks for posting that.  I think I may be doing this project later in the summer.  Any idea how the front compares?  I think I have one front and one rear that need replacing.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline Novadon
  • 205
« Reply #3 on: June 03, 2010, 03:29:31 AM »
Front bearing info...
http://www.suzuki-forums.com/1g-2001-2006-xl-7/31078-wheel-bearing-bad-can-i-fix.html
http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/38531-2000-grand-vitara-ltd-bearing-replacement.html
Also, with regard to swapping out the entire rear from a donor...I see that you are 4WD, so differential gear ratios have to match whatever you have up front too.   ;)
03' Honda Odyssey
Offline bzzr2
  • 1011
« Reply #4 on: June 04, 2010, 04:33:05 PM »
hey jay, just buy my whole tracker!  . . . .  only 100k on it and the body is still straight.
09 taco reg cab short box 4x4
Offline JayInBarrie
  • 107
« Reply #5 on: June 07, 2010, 05:27:21 PM »
Cuz has a press at work so everyone's right, I should just put new bearings in.
Ohh yeah, and update my little tag line (I've got a BL and 33" tires now with 5.13 gears. :laugh:)
HMMMM...........................................no.
Wife would kill me.
Would be tempeted if you wanted to buy my Smart Car, less then 75K km ::).
Offline JayInBarrie
  • 107
« Reply #6 on: June 09, 2010, 05:52:54 PM »
Thanks for the links.
I don't know how many inner seals I've replaced, but seeing the video made me take a REALY close look at the down loaded manual I have.
Wouldn't you know it, I'VE BEEN PUTTING THE SEALS BACKWARD!!!!! :P :P :P
Thanks again..
