rear end setup kits
  • 1302 Views
rear end setup kits
« on: May 29, 2010, 12:56:48 PM »
where is the best place to get rearend setup/install kits for trackicks?
Re: rear end setup kits
« Reply #1 on: May 31, 2010, 01:18:29 AM »
What are you looking to have done?
« Reply #2 on: June 01, 2010, 07:25:50 AM »
i just need to re bearing my rear thirdmember and hoing to put a locker in while in there.
« Reply #3 on: June 01, 2010, 11:45:03 AM »
You can order a full 3rd member from a company such as Trail Tough.  The easiest thing is probably to find a local shop that can do differential work, such as Randy's Ring and Pinion.  They should be able to install new bearings and setup your locker without issues.
With a good torque wrench and a vice you can set it up in your garage as well.
