CALMINI reverse shackles
  • 28 Replies
  • 6754 Views
Offline woof359
  • 111
« on: May 28, 2010, 11:48:23 PM »
I got my reverse Calmini shackles today, front came apart OK, and went back together fairly quick, Calmini says it shood raise the front 2 inches, Im thinking more like 3. When i get the back done Ill measure again. the rear shackles are making life difficult.
CHUCK AND MICHELLE
Offline lv2fsh
  • 312
  • 19
Re: CALMINI reverse shackles
« Reply #1 on: May 29, 2010, 03:42:26 AM »
 ;D get a bigger hammer. They are a bit tight but will go in. Try a little lube on them.
Offline woof359
  • 111
« Reply #2 on: May 30, 2010, 10:00:27 AM »
got it done, took maybe 3 hours in the garage using a floor jack, not to bad at all. stock shocks are way to short to fit now, front end looks way higher than back but using a levle on frame shows its close to being ok. Well post be4 and after later.
CHUCK AND MICHELLE
Offline unbridled
  • 33
« Reply #3 on: May 30, 2010, 10:09:48 AM »
What did you do with your front bumper to clear the towers?  Mine is just bent down a hair but I think it would be better if it was notched out just a bit.
Offline woof359
  • 111
« Reply #4 on: May 30, 2010, 08:08:35 PM »
i held it up to the new towers, marks how wide they were and used a hack saw to cut the bumper and then used a hammer to bend them inward.
CHUCK AND MICHELLE
Offline woof359
  • 111
« Reply #5 on: May 30, 2010, 09:33:27 PM »
i got to find some shocks now, old ones are way to short.
CHUCK AND MICHELLE
Offline woof359
  • 111
« Reply #6 on: May 31, 2010, 08:50:36 AM »
Calmini advertised 2 inches of lift, more like 2 1/2. nice kit. just need to trim bumper and new shocks
CHUCK AND MICHELLE
Offline woof359
  • 111
bumper
« Reply #7 on: May 31, 2010, 09:33:18 AM »
CHUCK AND MICHELLE
Offline unbridled
  • 33
« Reply #8 on: May 31, 2010, 09:42:52 AM »
Looks good!  Whoever did mine just grabbed the bumper and bent it down.
I'll be curious to hear what you go with for shocks.
Offline woof359
  • 111
« Reply #9 on: May 31, 2010, 03:53:29 PM »
Im going thru the Monroe catalog now, got frt and rr numbers  that come close. wish I knew some one that had some Calmini shocks and cood get the number off them.
CHUCK AND MICHELLE
Offline unbridled
  • 33
« Reply #10 on: May 31, 2010, 06:17:09 PM »
Yeah, I'll have to do more research.  I think the shocks on mine are Calmini shocks but I can't find any numbers on them anywhere and my Sammi rides like a nightmare.
Offline woof359
  • 111
« Reply #11 on: May 31, 2010, 08:11:59 PM »
i came up with 2 Monroes #'s 32270 for the back and 33128 for the front, gonna pick them up tomarrow if they have then in stock.
CHUCK AND MICHELLE
Offline unbridled
  • 33
« Reply #12 on: May 31, 2010, 10:12:17 PM »
Do you have a hard copy of the catalog?  I looked briefly at their site and didn't see specs.  I'll be curious to hear what you think.  I'm gonna try to get under my Sammy this week sometime if I'm feelin up to it.  Gonna check the shackle bolts and pull the shocks and look again for any markings.
Offline woof359
  • 111
« Reply #13 on: June 01, 2010, 03:03:03 AM »
I went to the Monroe site, found the factory shocks and wrote down the ext and compressed measurements, then the mount types, after that I went thru all the shocks and found some that were 2 1/2 longer. well see how they work.
CHUCK AND MICHELLE
Offline woof359
  • 111
« Reply #14 on: June 01, 2010, 07:57:01 PM »
i used Moroe 33128 on the front, 31000 on the back, back are a weeeeee short but workable for $20 shocks
CHUCK AND MICHELLE
