disable high idle?
  • 1745 Views
Bobthebiker
disable high idle?
« on: May 27, 2010, 01:02:32 PM »
I REALLY hate that high idle thing on cold startup on my sammy,  considering all I do is start it up,and get going after it builds oil pressure,  to me, that high idle component on my rig is no more than a total waste of fuel.
is there any way to disable it without buying a weber?
Re: disable high idle?
« Reply #1 on: May 28, 2010, 05:09:47 AM »
Check out Ack's FAQ for details on the carb, there should be an adjuster screw for the cold start idle.
Bobthebiker
« Reply #2 on: May 29, 2010, 11:34:11 AM »
I dont think an adjuster screw helps much when I want to eliminate that functon completely.
Offline oak_raid
  • 193
« Reply #3 on: May 29, 2010, 12:36:22 PM »
I have the choke wired open with some small zip-ties on my sammy.  It makes it pretty cold blooded at start up, but it dont idle high.
Bobthebiker
« Reply #4 on: May 31, 2010, 09:03:18 AM »
I basically disabled it using a heavy ziptie holding the high idle part so its not idling at 2500 when I start it up now. I'm MUCH happier.
Offline rascott
  • 669
  • 15
« Reply #5 on: May 31, 2010, 12:14:40 PM »
are you speaking about the high idle pot that is supposed to hold the thottle open slightly if the lights are turned on(and other loads/conditions)?
or the actual choke mechanism?
Bobthebiker
« Reply #6 on: June 04, 2010, 08:05:14 PM »
the choke mechanism.  it works alright now, aside from needing a second or two more time on the first start of the day, but thats no big deal.
