Stock sidekick steel wheels offset?
  • 9 Replies
  • 7703 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: July 04, 2004, 02:28:39 PM »
Im wonderin whats the stock rims offset cause my 235 are not sticking out at all.
I was thinking of gett some 15x7 and a -12 or 0 oddset so i can get a bit more stability.
So im debating 0,-6 , -12  for a offset
01 GRAND VITARA
Re: Stock sidekick steel wheels offset?
« Reply #1 on: July 04, 2004, 08:03:53 PM »
Offset and Backspace are two different
measurements, backspace is from where
the wheel mounts to the Trucklet to where
the bead on the tire seats, this and the rim
width will be what determins how far out the
tires will be of the wheel well, offset is the
distance from the wheel mount surface to where
the center of the wheel is welded to the outer
rim, if I remember that right, Somebody correct
me if I got that wrong.
235s fit very well on stock rims, and I see no need
to get differernt rims unless like you said you want
more stability, however, the SideKick has a wider stance
and a longer wheelbase to counter the "easy roll over"
problem brought on by CRs lies *friggen b|removethispart|@$+|removethispart|@rd$*
Good luck with your hunt, get/post some pics if you
do make a switch
« Reply #2 on: July 04, 2004, 10:46:27 PM »
Stock backspacing is 110mm which is about 4 1/4" for a Track/Kick. A Sammi is 95mm which is about 3 3/4". I run 33 x 9.5s MTs on the 95mm backspacing on my Track/Kick and the tread is just covered. If I had the MTRs then the side lugs would probably be counted as tread and it wouldn't be road legal.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: July 04, 2004, 10:59:00 PM »
Offset is the distance from the centerline of the rim to the wheel mounting surface. Positive offset means the mounting surface is towards the outside of the wheel as seen on many modern cars while negative offset is towards the inside of the wheel as seen in wheels with little backspacing. It is specified in millimeters and 'p' for positive eg. 25p  on a 7" rim  would be equivalent to 4.5" backspace measured from the inner edge of the rim to the mounting surface.
The stock 15x5.5 rims had a 25p offset or 3.75" backspace.
« Last Edit: July 04, 2004, 11:01:10 PM by cj »
Offline JDMCRX
  • 1110
« Reply #4 on: July 04, 2004, 11:25:25 PM »
I just want better stabilty in the winter i ordered some fender flares and a 3" lift so i wonder if i widen the stance 1" on each side if it would be a bit more stable in the winter.
01 GRAND VITARA
« Reply #5 on: July 05, 2004, 09:59:19 AM »
I fitted 1 1/4" wheel spacers and the difference in stability was quite amazing. It handled the same as it did when it still had a sway bar  ;D ;D
Offline JDMCRX
  • 1110
« Reply #6 on: July 05, 2004, 10:37:05 AM »
Cause i found some nice cheap rims there 15x7" with a 0mm offset i wonde how much wider they will sit
01 GRAND VITARA
Offline RifleRide
  • 29
  • Mentor a Child!
« Reply #7 on: July 06, 2004, 06:56:39 AM »
Since you are talking about wheels, what wheels from another vehicle will fit an '89 Kick?  I too have a stock vehicle but want some tire height and stability.  Since I'm interested in traction and some height, what is the largest tire that will fit in those wheel wells?
Offline 1bigtracker
  • 3409
« Reply #8 on: July 06, 2004, 11:08:00 AM »
most 5 lug fords do.  you might have to cut some of the center out of it to make it fit the hud.  tracker bolt padden is 5 on 5 1/2.
stu
« Reply #9 on: July 06, 2004, 07:28:18 PM »
That would be older Ford trucks, and the
after market wheels fit the hubs fine no
trimming stock wheels might need opening
