Samurai Proportioning Valve
  • 2523 Views
« on: May 26, 2010, 02:17:57 PM »
Have a leaky rear brake proportioning valve on the 87 sami.
Anyone know if there is an import donor vehicle out there in the scrap yards that would have a close fit, minimum amout of modifying to make functional?
Seems most sami`s sucumb to these leaky valves eventually...........
Offline my996duc1
  • 222
Re: Samurai Proportioning Valve
« Reply #1 on: May 26, 2010, 04:54:44 PM »
Good luck with finding a donor.
I ended up paying around $125 for mine from Suzuki.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #2 on: May 26, 2010, 07:53:36 PM »
Won't a Sidekick valve work? how is the Sammy valve attached to
the suspension system ?
« Reply #3 on: May 27, 2010, 09:56:10 AM »
What I wish to avoid...........
The sami valve bolts up mto the inside of the pass side frame rail, just back from the transfer case.
« Reply #4 on: May 27, 2010, 12:01:30 PM »
Does yours split into two lines, one running to each drum or is it a single line that goes through one drum then back to another?
Also, do you have two lines going back to the rear end from your front master cylinder or a single line?
