Has anyone tried this!!
  • 1752 Views
Re: Has anyone tried this!!
« Reply #1 on: May 26, 2010, 06:32:00 AM »
When you can get everything you need, pre-designed and tested for $150... the design, materials, fabrication and testing would not be worth the effort to me...
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/engine-upgrade/trail-tough-1-6l-engine-adapter-kit.html
« Reply #2 on: May 28, 2010, 05:07:11 AM »
The thread descibes how to fit the 1.6 without an adapter. Easiest method is to drill through for the bottom mounts, no design, fab or testing required. I haven't done it personally but I used to wheel with Breedsey so I've seen the conversion, its very tidy, could pass for stock.
« Reply #3 on: May 28, 2010, 06:36:58 AM »
I see what your talking about now... I thought they were fabricating their own plate  ::).
Offline samuride1
  • 42
« Reply #4 on: May 28, 2010, 05:25:07 PM »
Anyone else that would like to chime in????
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: May 30, 2010, 07:14:38 PM »
Call me lazy, but I have enough trouble keeping my Samurai running properly without worrying about problems created by attempting to fit a 1.6 onto a Samurai transmission bellhousing without an adapter plate.
I have an Calmini plate from way back in 2000 - which might not be as good as the full-circle plates available these days - but it gets the job done.
At $150, that adds up (conservatively)  to seven 4-hour days of tips from delivering pizza part time...  ;)
Ack
