aftermarket tach
  • 10 Replies
  • 2706 Views
Offline barlow86
  • 39
aftermarket tach
« on: May 22, 2010, 01:39:59 PM »
So I have an 86 sami. I wanted a tach so i bought a sunpro tach. I installed it in the dash wired it up, and blam  nothing happened.   It lights up when i turn the lights on so i know it is grounded and has power. the instructions say to wire it to the negative terminal on the  ignition coil..... tried that nothing happened. tried the other side of the coil nothing happened. now my question is ,  how stupid am i right now. I know it must be something small that im not noticing,   but Io have no idea what it is.   all help is greatly appreciated.
Re: aftermarket tach
« Reply #1 on: May 22, 2010, 01:59:40 PM »
were there any jumpers or settings on the tach that need to be set?
like for different engines like 4 6 and 8 cylinders
that and hooked up to the neg side of the coil and it's supposed to work,
or you might have a defective unit, that's what happens to me all the time
Offline barlow86
  • 39
« Reply #2 on: May 22, 2010, 09:37:38 PM »
there is a setting, but its on the 4 cyl like it should be. and if it were defective would it still light up with the lights like it does.  btw thanks for the help.
« Reply #3 on: May 22, 2010, 10:41:54 PM »
It should be pretty simple.  One goes to your 12v, another to ground, one for the back light and one to your coil.
« Reply #4 on: May 22, 2010, 11:09:01 PM »
Ya, the lighting up part has nothing to do with the
needle sweeping electronics, and BTW I use a tach
signal off of the back of the instrument cluster for
my MegaSquirt secondary EFI system because hooking
it to the coil directly caused it to not run, must of grounded
it out all the time
Offline MadMaxZuki
  • 77
« Reply #5 on: May 23, 2010, 06:54:37 AM »
Hook it up to positive on the coil i bought the same cheap piece of shit. instruction are wrong
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Offline barlow86
  • 39
« Reply #6 on: May 24, 2010, 07:50:41 AM »
I tried hooking it up to both sides. i had a buddy sit in the car and i touched it to both terminals and got no result.  i also attached them with a connector to the + and - sided and still nothing. at this point im pretty sure it is defectice. thanks for all the help if you have any other ideas that would be awesome.
Offline jow003
  • 403
« Reply #7 on: May 25, 2010, 06:28:31 AM »
i connected the red and white to the batt. light is always on but it works, grounded and green to the coil.  got one a couple y=ears ago, worked fine for about a month then just quit.  its like another said, piece of shit.
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline barlow86
  • 39
« Reply #8 on: May 29, 2010, 11:46:53 AM »
so I finally fixed the tach, I ended up just running the green wire to the positive terminal of the coil, the red wire direct to the battery, and grounded in the truck and the white to the dimmer like it said. I guess the red wire didnt like being attached to power in the cab so i ran it outside to the battery .  o well it works now.
Offline MadMaxZuki
  • 77
« Reply #9 on: June 02, 2010, 06:03:42 AM »
That just means you didn't find the right power under the dash. I noticed a lot of wires that seem live w a meter are really not. A lot of the lighting wires are open grounds. They wires are hot when turned off by what ever switching means and dead when turned of bc it completes the ground. There is nothing wrong with the way you did it though.
« Reply #10 on: June 02, 2010, 12:23:44 PM »
I picked up a wiring block and put it under the dash, then spliced it into the different voltages.  This way I can wire anything inside the cab to a single spot.
12v constant
12v ACC on
12v Ignition on
12v Lights on
Reference Ground
