Make sure you stop every 200 miles and run the vehicle in 2nd gear for 5 minutes while the transfer case is in neutral. Also, if you have manual hubs make sure they are unlocked. As wildgoody pointed out, when in neutral the front driveline turns.
An alternative would be to install a twin stick, s patter or H pattern shifter. Then you can use 2wd neutral.
