whiiiiiiiiining
  • 18 Replies
  • 3182 Views
Offline 90Stomper
  • 427
whiiiiiiiiining
« on: June 20, 2004, 03:48:02 PM »
my tranny (manual)whines alot.  mostly 1st and 5th gear.  in fifth it goes away over 3600 rpm.  pilot is pretty new and throwout and clutch are only 2yrs old......  other than the noise it seems fine, fluid level, smell, no slippage etc. are ok. ???   any ideas ???
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline idaholwb
  • 772
Re: whiiiiiiiiining
« Reply #1 on: June 21, 2004, 05:12:14 AM »
 Check your rear diff and rear axle bearings. I've run across that very problem in many zukis over the last few years.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: whiiiiiiiiining
« Reply #2 on: June 21, 2004, 07:13:21 AM »
If you push in the clutch and it goes away Its probabally a bearing in the trans. Ive had quite a few go out. Its actually kinda common.
Mike
Offline 90Stomper
  • 427
Re: whiiiiiiiiining
« Reply #3 on: June 21, 2004, 08:39:12 AM »
not sure but i dont think its in the rear.  sounds like its right under my shifter.
yes it goes away when i push in the clutch.  is it pretty much always the same bearing?  is it hard to change?  and how long can i run like this? :-/
Offline xamtex
  • 72
Re: whiiiiiiiiining
« Reply #4 on: June 21, 2004, 10:06:15 AM »
tranny may last for ages with a whine.its not a bad tranny to strip and rebuild and bearings can be obtained from a bearing shop.you will need pullers to remove the old bearings,and its best to refit new bearings with a press if possible.
factory manual has full instructions.
god must love crazy people,he made so many of them!!!
Offline xamtex
  • 72
Re: whiiiiiiiiining
« Reply #5 on: June 21, 2004, 10:11:05 AM »
factory manual download is here.
http://www.hardcore4x4.net/fsm/   ;D
Offline 90Stomper
  • 427
Re: whiiiiiiiiining
« Reply #6 on: June 21, 2004, 11:47:00 AM »
way cool, thanks.  my g/f is ganna be pissed cause when i have major down time i drive one of her cars to work ;D
any tips or tricks when doing this?  how long do you think it will take with the right tools.... hmmm just had a thought.  i was ganna put lower gears in the front and rear, should i just see about getting ones for the tranny and do it while it is apart?  i just have 30in tires so i am not looking for rock gears or anything...
Offline 90Stomper
  • 427
Re: whiiiiiiiiining
« Reply #7 on: July 01, 2004, 01:55:35 PM »
i just won the bid for a 90 manual trans on ebay.  so i am going to put it in (only has 100K on it) and then rebuild mine, do they make kits for this like with the sami kits ive seen?  where? any tips on doing this?
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: whiiiiiiiiining
« Reply #8 on: July 02, 2004, 12:07:19 AM »
you can drive it for quite some time with that whirring and you will know when its about to go because it will get quite loud and then the front bearing will blow out!!!! First it was Whiiiiiirrrrr. Then it was Whiiiiir Screeeeee, whiiiirrrr. Then it was Whiiiiiir, Screeeeeeeeeeee, KAPOW!!!!!!
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline 90Stomper
  • 427
Re: whiiiiiiiiining
« Reply #9 on: July 02, 2004, 12:58:45 PM »
ummm thanks but i think i will give the screeeeeech kapow thing a big miss ;D  pluss for $50 you cant really go too wrong.  btw NC_ZUK nice ride, but i think you need a bigger tow hook 8)  'and i even like the color' ;)
Offline nc_zuk
  • 406
    • www.samurai4x.com
Re: whiiiiiiiiining
« Reply #10 on: July 03, 2004, 02:07:43 AM »
LOL!! That hook is going away soon. I bought a Warn XD 9000 winch for 200.00 used and that was the hook on it. I will be ordering synthetic winch cable soon from Master Pull.
I don't blame you for wanting to miss the Screeeeeee kapow!! It wasn't pretty. the red in the pic is covering up the gear oil. (yes we cleaned up the oil and packed it out with us) I rode all weekend on a trail ride with it making aweful noises. Heck, most people thought that it was my fan belt squeeling. that is how bad the noise was :-/
« Last Edit: July 03, 2004, 02:08:02 AM by nc_zuk »
Offline Mike71
  • 1449
Re: whiiiiiiiiining
« Reply #11 on: July 03, 2004, 02:28:04 AM »
i love it when u have a problem and people have to keep pointing it out..i need a fan belt because it was squealing (my fault i know) but i had to goto work and back then to the store..i must have been told 6-7 times that i needed a fan belt  ::)...what did they think i liked the sound of the squealing? lol
Re: whiiiiiiiiining
« Reply #12 on: July 03, 2004, 05:30:07 PM »
Squeel like a pig
Skeeeeeeeeeeeeeeeeeeel  Skeeeeeeeeeeeeeeeeeel ;D
Offline 90Stomper
  • 427
Re: whiiiiiiiiining
« Reply #13 on: July 05, 2004, 02:49:29 PM »
LOL, dito
LOL sorry i couldnt resist, that thing is HUGE, but i only noticed cause mine is so small.  since i use an atv winch,  'mini-me' hook on the end. ;D
just so long as your not compinsating for something else :o ;)
Offline OneBadZuk
  • 30
    • American Mobile X-ray
Re: whiiiiiiiiining
« Reply #14 on: July 05, 2004, 03:50:53 PM »
I WOULD CHECK YOUR REAR PINION SEAL AND ALSO CHECK TO SEE IF REAR END HAS GHREASE IN IT. MY TRANNY WAS MAKING ALOT OF NOISE AND I GUESSED IT WAS ON THE WAY OUT BUT SURE ENOUGH THE REAR END WENT, FORTUNATELY A BUDDY OF MINE HAD AN EXTRA CENTER SECTION AND WAS NICE ENOUGH TO INSTALL IT FOR ME!! ;D
