Technical Discussion - Beginner / Repair
what other trucks can i salvage rims off of for my 92 sidekick
Big_Joel204
5
May 17, 2010, 07:43:51 AM »
i'm putting 31x10.5x15 wrangler kevlar MT/R's on my sidekick..what other vehicles can i salvage rims off of with the same bolt pattern but with with an offset?
Last Edit: May 17, 2010, 03:37:29 PM by Big_Joel204
hegemon
112
4
Re: what other trucks can i salvage rims off of for my 92 sidekick
May 18, 2010, 07:15:12 AM »
Here's some info on the wheel sizes
Bolt Pattern: 5x139.7 (5x5.5)
Center Bore: 108
Hardware:12x1.50 Lug
Offset: 00-20mm
And some other models that have the same bolt pattern, you just need to be sure that the center bore size is large enough.
Make
Model
Years
Dodge
1/2 ton, 3/4 ton Pick-Up
1984 - 1993
Ford
Bronco
1966 - 1996
Suzuki
Sidekick and Samurai
All
Ford
F-150
1948 - 1996
Jeep
CJ
1946 - 1985
ebewley
6554
64
ZUKIWORLD Online, Editor
May 18, 2010, 07:55:53 AM »
Nice helpful list hegemon... +1 TP for you!
Added to FAQ.
ZUKIWORLD ORDER
Today!
Big_Joel204
5
Reply #3 on:
May 18, 2010, 09:17:45 AM »
thanks hedge!! i'm goin junkyard shoppin tonight. i was also just informed that dodge ramcharger rims match aswell
pearlwhitez28
Reply #4 on:
November 06, 2010, 01:25:17 PM »
According to ;
http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?Makes=CHEVROLET%2FGMC&Models=TRACKER
Both the Dodge and Fords have a much smaller bore size, only the Jeep has the same bore, but the Stud size is imperial vs. metric.
Looks like the Jeep is the only vehicle with the same tire. Would be nice to find out if the spacing clears the disk brakes. If someone has used the CJ rim, it would be nice to hear from you.
beagle..t
1239
16
Reply #5 on:
November 06, 2010, 03:53:58 PM »
i put ford alum rims with +3.75 offset rims stick out abit but looks good for a wider stance i just got the centers honed and that was reasonable .ford centers are 87mm trackicks are 108mm not that much to hone but well worth it
V6 swap auto ,2 dr ,2" BL,2" jeffs kit 512 gears warn hubs and 30/9.5/15 BFG AT
tuxblacray
930
20
Building a Bigger Better Brute Samurai.... B-}
Reply #6 on:
November 06, 2010, 05:15:59 PM »
I put Ford factory Outlaws on a Vitara I had. I took the rims to the shop and milled the centers out to 4.25 on a Bridgeport mill. If you do this make sure you measure the rim backspacing 1st or be prepared to pick up a set of wheel spacers to be on the safe side.
I found the stock Outlaw rim would fit after milling but the caliper clearance against the back of the wheel center is not acceptable for off road use. Streetwise you could run them but a lil dirt /mud or heaven forbid a rock would play Hell on the caliper.
Tux...
I know the voices aren't real.... but they have some pretty kewl ideas!!! Tux..... ;-)
I get my Sammi parts here, and you can too...
http://www.mikodaindustries.com/http://stores.ebay.com/sticksnstones4x4samuraiparts
Skyhiranger
3734
122
I don't buy, what I can build
Reply #7 on:
November 08, 2010, 01:41:08 PM »
Stud size and thread is really irrelevant. Any ford, dodge or jeep wheel with the correct bolt pattern willl fit, no matter what the stud size is.
And stock samurai and trackick studs are 12mm-
1.25
thread, NOT 12mm-1.50.
brenzuk
43
Reply #8 on:
November 09, 2010, 07:36:57 AM »
All the factory Ford and Dodge wheels I have looked at would need the center bored. Some of the Dodges have really small centers, like the full time 4-wheel drive power wagons. Any aftermarket wheel on a Ford or Dodge probably has the big center though. Also, I thought Dodge 3/4 tons had 8 lug wheels.
tombstone
212
Reply #9 on:
July 31, 2012, 08:07:27 PM »
Dodge thru '93??No sir,Dodge thru 2001 has that 5 on 5.5 pattern,my '97 has it but the hard thing is finding a 15x10 or wider rim!!
Khodabear
155
2
Littleton Colorado
Reply #10 on:
July 31, 2012, 09:53:40 PM »
This is an interesting reference ...
http://www.roadkillcustoms.com/hot-rods-rat-rods/Wheel-Bolt-Pattern-Cross-Reference-Database.asp?Makes=GEO&Models=TRACKER+2%264+DOOR
1997 Tracker
1997 X90
tombstone
212
Reply #11 on:
August 01, 2012, 11:42:53 AM »
Sorry I meant the 1500 series Dodges and the 150 Fords have that 5 on 5.5 pattern,all the 4x4 have the larger rim center.
