Shocks
  • 1124 Views
Offline suzi_n_sammy
  • 184
  • Rock the Sam
Shocks
« on: July 07, 2004, 02:58:53 PM »
Word up fellas,
Today at work i was thinking i could use maybe a 1"-ish lift on the Sammy. I was thinking that if i were to buy 4 new rancho shocks, like on spider trax, that had 12.875 compression 20.50 extension and 7.5 travel that it would give me a little lift over the calmini shocks on there now?  because it looks like they are taller that the calmini shocks and the compression of the body weight would be the same right? Im just wondering. . . like to here suggestionss ( and yes i am fully aware that 1" body lifts are 80$ and rediculously easy to install)
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
Re: Shocks
« Reply #1 on: July 08, 2004, 02:25:07 AM »
If I read that correctly,  I don't think that changing shocks will give you any lift at all, but it will give you more suspension travel and maybe a better ride.
« Last Edit: July 08, 2004, 02:25:43 AM by Gravel »
Offline Effzuki
  • 41
  • When in doubt, punch it out!
Re: Shocks
« Reply #2 on: July 08, 2004, 02:50:20 AM »
Where can I get o 1" body lift?
88.5 Tin Top and never will be done with it.
  • 184
  • Rock the Sam
Re: Shocks
« Reply #3 on: July 08, 2004, 11:34:42 AM »
Somer- You read it right, and thats what i almost starting to think myself.
effzuki- Rocky-Road sells 1-3" body lifts for sammys
