Reduction Percentage
  • 1472 Views
Offline espo
« on: May 08, 2010, 10:15:57 PM »
How much reduction percentage do I need to get back to stock. Im running a sami with sammy t-case and toyota axles. Its lifted on 33" boggers?
Offline SnowSammi
  • 31
Re: Reduction Percentage
« Reply #1 on: May 08, 2010, 11:55:25 PM »
To get fifth gear back and good performance on/off road 6.4:1 w/33's,
this will drop you lower than stock but give a better boost in performance.
Remember to purchase stronger tranfer case mounts and bracket, bigger tires
and lower gears will twist things up.
« Last Edit: May 09, 2010, 12:01:57 AM by SnowSammi »
87 Samurai: OME springs & shocks, 30" Cepek mountain cat tires, K&N air filter, 6:4.1T-Case gears.
Offline Amilla
  • 1076
« Reply #2 on: May 10, 2010, 11:29:33 AM »
6.5:1's will do you just right.  You running 4.10 R&p?
Amilla
« Reply #3 on: May 10, 2010, 02:01:22 PM »
http://www.solemnwarning.net/transmission/
It even has Suzuki SJ series available with the aftermarket gear sets.  Just select your model, your axle ratio and put the tire size in at the bottom and calculate.
Offline espo
« Reply #4 on: May 10, 2010, 08:36:13 PM »
I think there 4.10's in the yota axels
Offline Amilla
  • 1076
« Reply #5 on: May 11, 2010, 12:20:53 PM »
4.10's and 6.5's are a pretty good mix for 33's.  The extra reduction from the R&p will make your 5th gear a little more useful.
Amilla
