Gas Gauge....senting unit specs?
  • 2019 Views
Offline heiney.5
  • 175
  • 9
« on: May 04, 2010, 04:53:42 AM »
I installed a fuel cell yrs ago and have never gotten around to make the gas gauge work....I believe the issue is the "new" sending unit is a GM type 90ohm. My gauge worked with the original tank/sender.
Does anyone know the resistance values of the original sending unit???
My plans are add series/parallel resistors to atleast get a decent fuel level reading... thanks in advance.
-Heiney5
Re: Gas Gauge....senting unit specs?
« Reply #1 on: May 04, 2010, 12:03:34 PM »
Found it!
Fuel Sender Resistance, I knew I saw this a few months ago.  :)
http://www.zukiworld.com/forum/technical-discussion-beginner-repair/fuel-sender-resistance/
Empty....110 ohms +/-7 ohms.
half....32.5 ohms +/- 4 ohms.
full....3 ohms +/- 2 ohms.
Offline heiney.5
  • 175
  • 9
« Reply #2 on: May 06, 2010, 06:09:23 AM »
thanks Drone... <applauded>
So those specs arent going to be changed "correctly" if I added resistors.... I'm pretty sure on a GM sender
Empty....0 ohms
Full.....90 ohms
However with that range I should have a rough reading on my gauge, although I guess now E= enough gas and F= find some gas....hmmm. I'll have to test that thought.
« Last Edit: May 06, 2010, 06:14:43 AM by heiney.5 »
« Reply #3 on: May 06, 2010, 02:24:31 PM »
Usually it is more resistance at empty, as it decreases the current running through the gauge and allows it to drop.  If you add 5 ohms it will bring it a little more in-line but it will still be backwards.  :D
