Jerry can fill-up How-To
  • 9 Replies
  • 5194 Views
Offline muskegtracker
  • 273
  • 10
  • Mr T
« on: May 03, 2010, 10:06:52 AM »
So the other day I was testing to see how far I could go on a tank of gas.  For those of you who haven't seen my build thread (http://www.zukiworld.com/forum/build-diaries-how-to-diy/mr-t-the-build/) I put a V6 and all the electronics, including the dash, into my Tracker.  Before I got stranded anywhere I wanted to push the limit and find out just how far I could go on a tank of gas and what the gauge read when I got there.  The inevitable occurred, and so I chugged to the side of the road.
The gas can I had with me had a large (diameter) spout that I knew was going to be a problem when filling the Tracker, which is now dead on the side of the road 20 miles from the closest gas station.  I guessed I would figure out how to get around that when the time came...
So I tried to quickly push the fat spout into the filler neck to get a good seal, but this happened...all over.
So I thought, maybe I could push harder, faster and get something to go in...nope.  Same result.
Well, now I'm getting a little concerned.  (I was on my way to work...)  I glanced around to find some wire or something to hold the flap in the filler open.  All I could find was grass,  not really interested in shoving grass into my gas tank.  Then a shiny flash caught my eye - a beer can.  (Plenty of those on the highways - sad isn't it?)  So I cut the top and bottom off of the can with my pocket knife-
Then split the can long ways and rolled it into a funnel/flap holder openner.  Inserted it into the filler and TAH DAH!
I then proceeded with a spill free fill which easily got me to the next gas station.
91 Chevy Tracker
  • 6554
  • 64
Re: Jerry can fill-up How-To
« Reply #1 on: May 03, 2010, 10:13:02 AM »
Very nice....
Offline TheZuke
  • 38
« Reply #2 on: May 03, 2010, 03:51:03 PM »
Good idea.  With the can that is, not the V-6.  Why would you ever crave more power enough to upgrade to a V-6?  I mean, isn't 1.6L enough.  ;)
Actually I've read Mr. T's build and I even filmed that short video.  In fact, I've driven that thing and the V-6 is dang sweet.  :)
So, congrats on finding out your fuel range and not having to call AMA.  What did the gauge read when it ran out?
 - Yo Lil' Bro
1990 Sidekick "The Zuke"  3/4" coil spacers, 33" tires and fender trimmin' to make em fit.  Not to mention all of the other trimmin'
1991 Sidekick "Rudy" Stock
Offline heiney.5
  • 175
  • 9
« Reply #3 on: May 04, 2010, 06:50:02 AM »
I like the "macgyver" type solution....way to utilize what you have.
I always liked a low fuel light, I wish my tracker had one, but atm I guess I just need to get the gauge working in general.....So does this V6 drink alot more gas?
  • 273
  • 10
  • Mr T
« Reply #4 on: May 04, 2010, 09:43:43 AM »
Thanks.
Actually it is pretty good!  With the old 4 cyl I never got much better than 300 km (180 mi) per tank (quite a bit worse with the turbo) and now I get a little better. ???  Probably around 25 mpg.  Not bad considering I'm running lower axle gears (5:12 instead of 4:30) and I don't have ridiculously large tires...yet.
91 Chevy Tracker
  • 4314
  • 167
« Reply #5 on: May 04, 2010, 10:28:55 AM »
You might find this surprising - but a sheet of paper will do a pretty good job as an emergency gas funnel - roll it lengthways with a taper and stick the narrow end into the filler neck, the neck will hold it rolled whilst you pour.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
  • 273
  • 10
  • Mr T
« Reply #6 on: May 04, 2010, 12:02:48 PM »
Excellent!  Thanks for the tip.
91 Chevy Tracker
« Reply #7 on: May 04, 2010, 01:26:52 PM »
Does that count as an open container?  :D
« Reply #8 on: May 06, 2010, 11:58:38 AM »
In an emergency you can even use cardboard for a funnel.
« Reply #9 on: May 08, 2010, 03:39:28 PM »
I must have got lucky, my jerry can has a screw on neck that fits the hole just right. Still drips all over though. Props on using your noggin to get out of a jam!
