whats the diff between and 88 and a 88 1/2 Sam ?
  • 2556 Views
Offline woof359
  • 111
« on: May 02, 2010, 06:18:56 PM »
just got my second Sam, cant belive I got rid of the last one that was a 86.  but I keep seeing ad,s wanting to know if its an 88 or 88 1/2. not sure what I have now.
CHUCK AND MICHELLE
Bobthebiker
Re: whats the diff between and 88 and a 88 1/2 Sam ?
« Reply #1 on: May 02, 2010, 06:20:40 PM »
honestly, I have no idea,  but I think 88.5 they put the TBI injection in, and earlier had carbed,    I know the dash is different.
Offline woof359
  • 111
« Reply #2 on: May 02, 2010, 06:24:23 PM »
I have square vents and a carb, gonna try and find a build date on it.
CHUCK AND MICHELLE
« Reply #3 on: May 02, 2010, 09:00:37 PM »
90 was the first year for EFI.
88.5s have square vents in the dash, a different instrument cluster, larger bolts and bolt patterns on the driveshafts, a single crosspin carrier in the front axle, a lower 5th gear ratio, 3/8" (10mm) square drive drain and fill plugs for the axles, tcase and tranny, a single rear rubber brakeline, different connectors on some of the wiring harness plugs in the engine bay.  There may be more differences....but that is all I can remember off the top of my head.
Yours may have all, some or none of what I listed above.....88.5s were transition samurais, so they were changing parts as they ran out of old stock.
Offline yzf438
  • 94
« Reply #4 on: May 04, 2010, 09:21:27 PM »
I m kinda curious to know if miine is a 88 1/2 the dash vents are square or rather rectangled.  anyone have a pic of what that dash looks like.  I know I tach about 3400 at 60  I understand they are a tad bit lower geared in 5th.
« Reply #5 on: May 04, 2010, 09:29:20 PM »
The dash says it is an 88.5 or later.
If you want to know if the tranny is an 88.5, then check the drain and fill plugs.  3/8" square drive=88.5.  hex head (22mm or 24mm...can't remember which)=88.
« Reply #6 on: May 05, 2010, 01:28:25 AM »
I believe the 88.5 have softer springs from the factory as well, for the Cadillac of short wheelbase rides.
