T.CASE 4.24 INSTALL PLEASE HELP.
  • 10 Replies
  • 2888 Views
Offline camokick93
  • 47
  • SUPPORT OUR TROOPS
« on: April 25, 2010, 09:22:58 AM »
HI guys,I'm in a fix, >:(just installed my 4.24 tt gears in a 97 t.case and I'm left with one last ball and can't figure out where the
f... it goes >:(,both the counter shaft lock balls where succesfully placed,shif ball placed,low range rod ball in place,ball under
4wd switch placed,and I don't have the low switch,is there a ball inside the case I may have forgotten?? The calmini pictures
on gear guide are of no help. ??? I'm desperate.
Simon.
93 4door sidekick,5spd,3in calmini,ome frt coils with 2in spacers,calmini winch bumper,8500 superwinch,calmini front skid,custom rock slidders,custom belly pan,frt ome shocks with upper mount flip,4.24 t-case gears,truck painted camo,hence my user name.I have rear ARB,calmini header exh. combo to be installed soon.FOUR DOORS KICKASS
Re: T.CASE 4.24 INSTALL PLEASE HELP.
« Reply #1 on: April 25, 2010, 12:21:43 PM »
How big is it?
« Reply #2 on: April 25, 2010, 12:28:04 PM »
There is a ball that goes between the shifter shafts, I leave it out so
if you want a twin stick or a 2WD low you don't have to take it all
apart to remove it, there are two balls under springs that keep the shift
shafts in place so they drift while driving, there are small BB size bearings
that prevent the counter shafts from turning in the case.
Offline camokick93
  • 47
« Reply #3 on: April 25, 2010, 02:12:38 PM »
Hi thanks for the quick reply,well the ball is medium in size,the smallest ones are for the counter shaft,of the 2 big ones,one for
the 4wd switch that is on top of trany,and the other would go in the block that is locked with a sping pin on that low shaft.
the balls of the 2 shift shafts that are side by side are in place under those 2 14mm bolts on top,am I making any sense?
« Reply #4 on: April 25, 2010, 05:32:01 PM »
So did you put a ball between the shift shafts?
If not, that's the one, and you did yourself a favor, it just
locks the low range shaft until the 2-4 shaft is moved, with
it out you can put in a twin stick, or a 2WD low kit.
Don't worry about it
Offline camokick93
  • 47
« Reply #5 on: April 25, 2010, 08:19:53 PM »
Hi I'm back,I only have a few minutes.The one I can see that is in between is one that activates the 4wd light switch,and its
one of the big ones and that one I need for my light,but I'm still left with an extra ball,I've been toying with in my mind for the
past 2 days and I just can't remember that ball goes.
Anyway I will call my zuki dealer in the morning an ask if he can fax me diagram or some sort of parts layout,I have to figure this
out,you know,I don't realy care for the t.case at this point,its me forgetting where this ball goes that pisses me off.
Ok I have to go,thanks WILD,I will let you know how it goes.
I will try to post pics soon.
Simon.
« Reply #6 on: April 25, 2010, 08:42:38 PM »
Ya, that's one of them, this one you would have to pull out the high/low
range shaft to get the ball in there, it fit's in between the 2 shafts, I'm sure
that's the one you left out, as you covered all the other ones.
Like I said, not to worry, if I had another case I could take a pic to show you
Offline camokick93
  • 47
« Reply #7 on: April 26, 2010, 06:20:05 PM »
Hi I'm back for another few minutes,turn's out that my dealer parts layout are of no help,my t.case is at my friend's shop so i
can't check it out now but in the next few days I will go and remove that shift rod just to satisfy my curiosity,and I ordered
a new counter shaft O ring that I nicked when I removed it,should get it wednesday,last thing I need is a leaking case
once installed :-\. thanks buddy I will write back soon.Greetings to every one.
Simon.
Offline heiney.5
  • 175
  • 9
« Reply #8 on: April 27, 2010, 06:24:43 AM »
Hopefully you figured it out, if its the ball mentioned I'm assuming it will look like this.
There is a bigger "bolt" on the side of the tcase near the shifter that holds a spring+small rod+ball as shown in picture. You pretty much remove these for a twinstick setup, which is why I have this pic...If you remove this bolt on the side you should see the parts pictured, of coarse you may need a magnet to get them all out.
If you remove that bolt and have all the pictured then I guess the ball goes somewhere else?  ???
Offline heiney.5
  • 175
  • 9
« Reply #9 on: April 27, 2010, 06:43:18 AM »
Well after more thinking I was trying to remember all my tcase parts, and locations....I'm not as versed in tcases as wildgoody....but these links helped me remember more, and might be helpful for future "searchers."
98-service manual on Acks Faq....section 7D is tcase
http://www.acksfaq.com/pdfs/sidekick_drivetrain_manual.pdf
Calimini Install in the archive somewhere.
http://www.zukiworld.com/month_010103/feature_calminirockcrawler_sidekick.htm
Offline camokick93
  • 47
« Reply #10 on: May 02, 2010, 04:03:39 PM »
Hey dudes! I'm back for a few minutes again,Wild you were right,it's the interlocking ball in between the two shafts that I forgot,so I opened it and put it back where it belongs,at this this point I dont need 2wd low anyway,until I find a proper
shift boot system,like i said before I'm pretty anal in keeping everything stock looking as much as possible,well if all goes well
I will be installing the case with another tranny next weekend,my existing tranny is shot,needs bearings so I will keep that one
and fix it so that I have a spare tranny,can't wait to feel that granny low gear!
thanks Heiney for the info really helped me.I just got me a new digital camera,I have a few really nice pics I will try to post
the thing is I'm notat all computor savy.ah shoot!! I just spilled my beer! got to go be back soon.
Simon.
