Noise neer intake
  • 1215 Views
Noise neer intake
« on: April 23, 2010, 09:23:21 AM »
 ??? Can someone tell me what a low tone (horn like) sound could be coming from the intake, carburetor area ? It only happens sometime and runs good would like to know before it becomes a real problem, it is a stock 1.3 . ???
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: Noise neer intake
« Reply #1 on: April 24, 2010, 12:17:04 PM »
could be a vacuum leak they can make wierd sounds
Bobthebiker
« Reply #2 on: April 24, 2010, 12:21:28 PM »
could be a vacuum leak, like fordguy said,   or maybe some sort of loose part that from time to time contacts the right motor part and makes noise from the vibration.   sounds weird, but I've had it happen before on mine, more on the exhaust side with that heat shield ratting, but the concept is the same.
« Reply #3 on: April 25, 2010, 08:26:31 AM »
Thanks , guess this is not a common problem with sammys,will try to track it down.
Offline 89tracker43000
  • 47
  • my tracker
« Reply #4 on: April 28, 2010, 12:05:37 PM »
pcv valve makes noise when it goes bad it screws in to the intake and there is a hose that goes to the valve cover. when its making the noise pinch off the hone in the noise stops thats what it is. had this happen to me be 4.
