wierd noise coming from t-case
  • 1460 Views
« on: April 22, 2010, 07:39:17 AM »
once i hit about 3000 rpms a high pitch wind up come from the t-case and gets louder the more rpms. any ideas?
  • 4314
  • 167
Re: wierd noise coming from t-case
« Reply #1 on: April 22, 2010, 07:55:30 AM »
Did you check the oil yet?
You don't specify what vehicle you're inquiring about - some of the t/cases are gear driven, others have chains, and you'll hear them if the oil is low - other than that, bad bearings.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Bobthebiker
« Reply #2 on: April 22, 2010, 05:56:23 PM »
sounds like changing your transfer case oil would be a wise idea,  see if it shows any shavings of metal in it or something.  if it does, you've got problems for sure.
« Reply #3 on: April 22, 2010, 08:13:44 PM »
its a 1986 samurai, and i went to the mudbog with it and it started doin it at the end of day. i draine the gear oil and it had alot of mud in it, so i cleaned it out then put new gear oil in it and it still does it
« Reply #4 on: April 22, 2010, 08:34:50 PM »
The bearings might be chewed up then, I knew there was a reason I don't like mud bogging.
You should extend the breather to a higher spot so this doesn't happen again
« Reply #5 on: April 22, 2010, 08:38:52 PM »
yea i love mudding thts mainly all its guna be in. ideas on how to do tht?
« Reply #6 on: April 22, 2010, 10:06:32 PM »
Locate the vent and put a rubber tube up to the hood level, might
even want to run it into the air filter box
