Hi suzuki support...
  • 1383 Views
« on: April 21, 2010, 08:38:03 PM »
Hi my name is April Conlu...im an owner of a suzuki samurai 1997...pls give me advise because it seems my steering wheel is so unstable..right now its on 2 wheel drive..and it has this tendency to WOBBLE..how can i address this problem..by the way my tires fits ok theyre not loose...
Bobthebiker
Re: Hi suzuki support...
« Reply #1 on: April 21, 2010, 09:08:45 PM »
My 87 does that too,  all stock,  I'm going to have an alignment done and rebuild my front brakes.  I dont think its my steering box, since that has pretty much zero slop in it.
I think it might just be a samurai design thing, or it might be alignment, a brake issue, or a wheel bearing issue, depending on how well yours has been cared for.
« Reply #2 on: April 21, 2010, 11:39:36 PM »
What type of wobble is it?  One of the most commas issues is the tie rod ends becoming worn, this introduces the death wobble quite easily.  Pull your tie rod's off and inspect them, if they are loose at all replace them immediately.
  • 6551
  • 64
« Reply #3 on: April 22, 2010, 07:27:06 AM »
Tires out of balance, tie rods like Drone said, wheel bearings loose/need service, or possibly the king pin bearings. I'd check in that order...
Offline Cuthulu
  • 384
« Reply #4 on: April 22, 2010, 10:24:14 AM »
If it is the tie rods, or wheel bearing you want to get it fixed soon.  Those go out while driving and it could be very bad.
Bobthebiker
« Reply #5 on: April 22, 2010, 11:38:31 AM »
Mine probably needs new tie rod ends, and some new wheel bearings.  its just an issue of money.
Offline SnowSammi
  • 31
« Reply #6 on: April 24, 2010, 10:40:15 PM »
Sammi's don't wobble very stable all speeds i"m with Erick on this one check tires
but do check it out there is an issue.
87 Samurai: OME springs & shocks, 30" Cepek mountain cat tires, K&N air filter, 6:4.1T-Case gears.
