Technical Discussion - Beginner / Repair
samurai horn relay
samurai horn relay
3-S-RACER
10
samurai horn relay
April 21, 2010, 05:11:59 PM »
took out the horn and connect it directly to the battery it worked fine so now i went on to test the horn wires with the test probe had some body push the horn button but i did'T GET ANY POWER WAS THINKING IF IT COULD BE THE HORN RELAY BUT DON'T KNOW WHERE IT IS LOCATED CHECKED FUSE IT WAS GOOD ALSO.
Drone637
8121
116
Evil Cow
Re: samurai horn relay
April 21, 2010, 11:36:43 PM »
It is most likely a switch issue. On the SJ there is 12v applied to the horn and it grounds out through the steering wheel.
wildgoody
8134
67
April 22, 2010, 08:10:15 PM »
Most of the Suzuki electrical system works like that, the switched
side is the ground, the wires are "hot" all the time
3-S-RACER
10
Reply #3 on:
April 23, 2010, 04:38:20 PM »
I disasembled the steering wheel yesterday hooked up the horn and grounded out the wire on the steering wheel but nothing should there be power on the steering wheel wire then i have an 1988.5 sammie and also should i discard the idea of the horn relay been bad.
