looking for gears
  • 1599 Views
Offline 87zukini
  • 35
looking for gears
« on: April 19, 2010, 05:20:39 PM »
i installed my tracker 5:12 and it was ok till the other day i hit a 3 ft shelf with both front tires at once my chromolly shafts held ok but i cracked the housing and chipped my ring and pinion . i have a toyota front axle but cannot find 5:12 gears for it and do not have a toyota rear so im trying to match up my gears . does anyone know if these are available? thanks for any help
Re: looking for gears
« Reply #1 on: April 19, 2010, 07:58:44 PM »
I don't believe 5.12s are an option with toyotas.
Offline 87zukini
  • 35
« Reply #2 on: April 20, 2010, 05:22:34 AM »
i cant find them i may have to go to a dana 44 cut down in the front instead
Offline OHIO_ZUKI
  • 53
« Reply #3 on: April 20, 2010, 06:30:22 AM »
I .....are you sure those are 5.12's? You have a Yota front axle with 5.12's? ???
i Kant sPel.
« Reply #4 on: April 20, 2010, 09:26:43 PM »
I read his post as to say that he has a toyota axle (not installed in the trackick) and he is wanting to install it and put 5.12 gears in it, so it will match his stock trackick rear axle ratio.
Offline 87zukini
  • 35
« Reply #5 on: April 21, 2010, 06:14:32 AM »
thats correct i have a yota front axle its 4.10 though id like to match my tracker rear but i cant find 5.12 or 5.13 toyota gears. so im considering a cut down 44 i have a jig to cut it down to wrangler width . only thing is i now have chromolly samurai axles and a front housing with fully rebuilt knuckles.
