transmission output seal
  • 1108 Views
Offline MadMaxZuki
  • 77
« on: April 18, 2010, 02:27:48 PM »
i have an 88 samurai, i am leaking oil from the back of the tranny. i pulled the drive shaft out and im  not sure what to do next to get to the seal.
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: transmission output seal
« Reply #1 on: April 18, 2010, 04:10:12 PM »
You can buy a seal puller and pull the old seal out.  Then use a clean rag and clean it up in there make sure you lube the new oil seal and when you install it make sure you are carefull not to bend it, or push it in uneven.
