I just put a new transmission in my 88 samurai and the arm on the outside of the transmission for the throw out bearing was taken off so i put it back on 90 degree's to the ground, put on the new clutch cable and hand tighten the adjusters and then gave it another 1/4 inch turn. The gears didn't grind when i put it in gear but the clutch engages close to the floor. When i put it in neutral it pulls a little bit and drops rpm's. I don't want to smoke my new clutch because i didn't adjust it right. Does any one know what i am doing wrong. Any help would be apprecited
