Technical Discussion - Performance / Modify
1.6 EFI 8 valve fuel pump
Chuck S
36
April 15, 2010, 07:11:14 PM »
I got my motor in and ready to run, but I am having fuel pump problems. I am using the full TBI setup from a '92 Tracker. What fuel pump do I need and where can I get one? I understand 40-45psi is perfect from a F150. I called the local O'Reighly's and they have a 90psi on the shelf for $85.00.
wildgoody
8134
67
Re: 1.6 EFI 8 valve fuel pump
April 15, 2010, 08:42:27 PM »
The fuel pressure is regulated by the EFI systems Fuel Pressure Regulator,
it makes no difference if the fuel pump puts out 50 or 100 PSI, the regulator
will return the extra fuel to the gas tank, so make sure to put in a return line also
Chuck S
36
April 16, 2010, 07:22:29 AM »
That's good to know. Low range Offroad sells a high pressure pump for $79.00 that I will order as soon as they open this morning.
