Radiator hose
  • 1464 Views
Offline Mvjlt
Radiator hose
« on: April 14, 2010, 12:22:50 AM »
I have a 1987 Suzuki samurai jx I have been noticing that that upper and lower radiator hoses have been sucked flat after my Sammy is warm. I have replaced the radiator cap and thermostat. My question is, are the stock radiator hoses a hard plastic or a hard rubber. I was looking on petroworks.com and they had a hard plastic radiator hose. (mine are rubber) I will probably end up replacing both the upper and lower hose anyway. Do yall know a trusted place on the net to buy them?
Re: Radiator hose
« Reply #1 on: April 14, 2010, 05:00:17 PM »
The hoses are probably just old and getting soft.  Stock radiator hoses are reinforced rubber hoses...that is what I would replace them with.
Bobthebiker
Re: Radiator hose
« Reply #2 on: April 14, 2010, 05:29:13 PM »
I'd just buy them from a local shop.  they're just traditional reinforced rubber hoses, as skyhiranger says.
Offline woof359
  • 111
Re: Radiator hose
« Reply #3 on: April 15, 2010, 10:39:32 AM »
thats because you either have the wrong cap, or it just bad we see that once in a while at our shop. if the hose pops back when you take off the cap its the cap, usally you notice it after the engiine cools down.
CHUCK AND MICHELLE
Offline Mvjlt
Re: Radiator hose
« Reply #4 on: April 15, 2010, 08:23:19 PM »
As soon as I take the radiator off you can hear the vacuum releasing and the hoses go back to normal
Offline rascott
  • 669
  • 15
Re: Radiator hose
« Reply #5 on: April 15, 2010, 08:43:31 PM »
sounds like that cap isn't right- it should release pressure as the engine warms up(you have the overflow tank?), then let it draw back as it cools down.
mabe
Offline woof359
  • 111
Re: Radiator hose
« Reply #6 on: April 16, 2010, 09:13:23 AM »
YEP, BAD VALVE IN CAP, WE SEE THAT ONCE IN A WHILE. NEW CAP, CHEEP FIX
CHUCK AND MICHELLE
