fuel injection
  • 1314 Views
Offline yzf438
  • 94
fuel injection
« on: April 11, 2010, 12:36:00 PM »
question for all.
can u turbo a weber??
will the sidekick fuel injection work on the 1.3?? if I put in the total wiring and computor.
Re: fuel injection
« Reply #1 on: April 11, 2010, 01:27:37 PM »
1. Only if you use a suck through set up.
2. Yes but why not use the Sammy EFI?
Offline yzf438
  • 94
Re: fuel injection
« Reply #2 on: April 11, 2010, 03:23:06 PM »
seemed like it would be harder to find the samurai fuel injection set up.  have a sidekick one that I could get.
suck through set up?
had one guy I talked to told me to build a box for the weber do it that way.  any imput on that?
Re: fuel injection
« Reply #3 on: April 11, 2010, 09:02:12 PM »
Ya the box will work, but taking the box apart to tune is a pain, and you will need a high pressure
fuel pump and a boost indexed fuel pressure regulator to keep the fuel flowing at a constant rate.
If you starve an engine under boost, things can go boom in a hurry
Offline KJMac
  • 280
Re: fuel injection
« Reply #4 on: April 14, 2010, 11:18:29 AM »
My friend had a weber on his single seat sandcar with a GPZ 1000 in it with a custom manifold and a carb hat on the weber. I have the carb hat now withg a bosch blow off valve clamped on it. It worked good! I have the electric fuel pump and rising rate regulator too! He broke the trans befor he had it dialed in but it was close.
KJMac
