belt driven turbo??
  • 1944 Views
belt driven turbo??
« on: April 11, 2010, 09:43:26 AM »
Hi Guys,
I'm new here but am looking for info on putting in a turbo. Does any one make a belt driven turbo? and do i need to put in a header or can i use stock exaust and do some welding to it?
thanks
Bobthebiker
Re: belt driven turbo??
« Reply #1 on: April 11, 2010, 10:01:27 AM »
someone correct me if I'm wrong, but isnt a belt drive turbo a supercharger?
to run a turbo, you'll need to make, a header to accomodate it.
« Reply #2 on: April 11, 2010, 12:11:02 PM »
There is a belt driven super charger that looks like a turbo, but in
the true term, turbochargers are exhaust driven, and superchargers
are belt driven.
Paxton superchargers are belt driven, and look like a turbocharger, the
other style is a Roots type, like you see in drag racing, and then there
is a different style that was developed by VW called the G-ladder which
would probably be the hardest to find.
The Subaru turbo is fairly easy to find and boost is set to 8 PSI, which is
a little high for stock pistons (cast) but will work quite well.
The big question is do you have an 8V engine or a 16V engine???
I would not try to put a turbo on an 8V, there is just too much fabrication
to get it all working right, took me about 2 years of playing with different
systems and tuning to get it working well, so if you want a turbo motor, start
with a 16V engine and save yourself a lot of time and fabrication.
Bentparts has a good setup, I would start by researching what he has done
« Reply #3 on: April 11, 2010, 01:27:50 PM »
Thanks,
Its a 16 valve bone stock right now. I was looking at the electric super chargers but the affordable ones look like a scam.
James
« Reply #4 on: April 11, 2010, 08:40:35 PM »
Save your money and go buy a leaf blower, at least when it doesn't
work you will still have a leaf blower to clean your yard with  ;)
« Reply #5 on: April 12, 2010, 01:30:21 PM »
What, you mean that electric supercharger and 150HP chip I bought on ebay really doesn't work?!!!??! :laugh: It was only $39.95 for both!
