DIY Polyurethane Bushings - Project Failed
  • 20 Replies
  • 13242 Views
Offline yellow2000S/R
  • 152
Re: DIY Polyurethane Bushings - Project Failed
« Reply #15 on: April 09, 2010, 12:23:56 AM »
I recognize that thread.  :D
What you want to make sure of is that the width where the joint replaced the existing bushing is the same.  Otherwise you will need to use a washer or a similar device to act as a shim to make up the difference.  If you do it right you will have the same length as before, just with a beefy new joint.
The rig you want to look at for whitfield's Tracker.  I'm pretty sure his is the one where I saw the modifications done to the stock arms to lengthen them a bit, as it's the only reference I can find on the site.  But almost all his pictures are dead.
I lengthened my arms 5/8" and shifted the ball joint forward 5/8" as well. I replaced the stock bushings with Energy Suspension ones. The center sleve fits a 5/8" bolt so I just drilled out the front mounts that are factory 9/16". The OD of the ES bushings was perfect for the 9/16" side but the other was larger. I had some 1.75" OD .125" wall tubing that it fit inside of perfect so I welded a section of it into the stock arm then the ES bushings fit great. A quick coat of paint and it was done.
I need to still get some 5/8" washers like said tho. I put the arms in as is and it crushed the factory brackets in slightly. I'll probably only do 1 per side as that's all that was needed. I know I should have taken pics but yea.
  • 4320
  • 167
« Reply #16 on: April 10, 2010, 08:58:36 AM »
Interesting! A urethane bushed ball joint..
http://www.currieenterprises.com/cestore/johnnyjoints.aspx
More of a urethane bushed heim (or rose) joint - heim joints are very common on track cars, but generally not a good idea for road use and less so for off-road, because dirt destroys them rapidly.  There's also very little cushioning so you feel every rut and bump in the road.  A urethane bushed one would take care of both of those issues.
Properly built there should be no alignment issues - the potential for greater sideways movement does exist, but that's what the panhard rod is there for.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
« Reply #17 on: April 10, 2010, 11:27:21 AM »
And they rattle once they get worn in, and that gets real annoying.  :D
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« Reply #18 on: April 10, 2010, 12:22:47 PM »
I see Johnny Joints in my future...  :)
Offline chris85
« Reply #19 on: May 03, 2010, 07:04:37 AM »
 You could try this.not guaranteeing it will work.
 1.press bushing out.
 2.fill bowl with plaster
 3.put Vaseline on bushing.put in said plaster. to create a negative mold.
 4.fill mold with urethane.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #20 on: May 05, 2010, 08:50:58 PM »
