More work done, but the boss is not too happy cause I been sneakin it in between cars..
I decided to hold off on the body mount repair and just weld the trailing am bracket to the frame. I'll have to repair the other side as its all rotted out, so I decided I'll do both at the same time. My main goal is to get it on the road ASAP, and it's close, in fact I took it for a test drive today and got it up to about 35 MPH, and it felt ok. I used the upper link from the junkyard and had to straighten the bracket. I also slotted the holes in the tabs to give the axle a little left to right adjustment. Aside from the body mount stuff, I just gotta get a few nuts and bolts from the hardware store, crank everything down, bleed the brakes, and do an alignment.
And I guess it wouldn't hurt to let a body guy look at it, the whole body kind of shifted to the side. All the doors close but the pass/rear door is kicked out at the top. The rear of the body basically went from looking like this: l l to this: / /
Pics of my (hopefully) strong welds (sorry about the crap quality):
