Sometimes people don't know.The sensor is pretty easy to pull, it is on the front of the oil pan and only held on with a single bolt. It should be free of oil, if there is some then either your oil pan isn't sealing or the front main gasket needs to be replaced.
Do you know when the last service was done to replace the timing belt?
