86 Samurai front to rear diff swap
  • 3433 Views
« on: March 17, 2010, 09:17:25 AM »
Are the 3rd members interchangeable on stock axels from the same vehicle?
  • 6558
  • 64
Re: 86 Samurai front to rear diff swap
« Reply #1 on: March 17, 2010, 01:51:44 PM »
I think your asking if you can swap 3rd members front to back on a Samurai. If so, then the answer is no. While the 3rds are very similar and will physically fit, one must change the sidegears, which do interchange, in order to swap front to back. The front axles are 22 spline and the rear are 26.
Hope that helps, Eric
Offline blknight87
  • 417
« Reply #2 on: March 17, 2010, 01:54:35 PM »
so are you saying Eric, that you can easily swap out the side spider gears, and then you can install it into your rear axle housing? is it that simple?
87 sammy-JX
U4WDA/IBZK
1.6 8V w/ MY-SIDE2-44mm SE carb
Thorley Header
Rebuilt trans, and t-case w/6.5-1's
SPOA 6"s w/ Rancho springs
275-85-15's buckshot mudders
Rino Line
RIP "BLKNIGHT" FOR YOU ARE MISSED
  • 6558
  • 64
« Reply #3 on: March 17, 2010, 02:09:27 PM »
Yeah. The sidegears are the difference between front and rear 3rds. So if you feel comfortable changing them, (should put in a locker while your at it) then yes, it's that simple.
Plus one for helping? :)
« Reply #4 on: March 17, 2010, 04:26:01 PM »
Hey ebewley thanks for the help thats exactly what I needed.
Offline blknight87
  • 417
« Reply #5 on: March 17, 2010, 07:26:47 PM »
here's another Eric.... Thanks for ALL your help in the forum... no matter how big, or small the problem is, you always seem to have the advice some one is looking for... my hat's off to you my friend!
87 sammy-JX
U4WDA/IBZK
Thorley Header
Rino Line
