antifreeze leak
  • 2325 Views
Offline WDSBTR
  • 27
antifreeze leak
« on: February 25, 2010, 07:43:21 PM »
ill try to explain this the best i can. maybe someone mite have a idea
 on the passenger side of the block underneath the air intake and TB right up under were you cant see i seem to be leaking antifreeze. its not a constant spray and its spraying up. i Just did the hoses hopping it would fix the problem but no luck ???  thanks
Re: antifreeze leak
« Reply #1 on: February 26, 2010, 12:24:14 AM »
There is a small hose that goes from the cooling tube to the bottom of the intake,
and then there are heater hoses, are those the ones you replaced?
Offline WDSBTR
  • 27
Re: antifreeze leak
« Reply #2 on: February 26, 2010, 08:28:12 AM »
i replaced the two going to the heatercore
Re: antifreeze leak
« Reply #3 on: February 26, 2010, 08:53:08 AM »
Then you might want to change the little one that's going from the
cooling tube to to the intake manifold, it's about 3/8" ID line, I blew
one wide open once, I had put the wrong type of hose on it.
The piece is only like 5-6 inches long and has a 90* bend in it, but
straight hose will bend and work fine as long as it's not over the length
that is needed it won't kink
Offline zukimoo
  • 330
Re: antifreeze leak
« Reply #4 on: February 27, 2010, 12:30:44 PM »
is the leak coming from the little hole in the water pump? if so then it's telling you that it's going to break and you've got to change it before it fails.
There is also the metal pipe that tends to leak a little when the o-ring dries. Can you take a pic of the area?
06 Baja Buggy
Offline WDSBTR
  • 27
Re: antifreeze leak
« Reply #5 on: March 04, 2010, 06:56:13 AM »
sweet. found the little thing. one of the heater core hoses runs under the intake. i replaced the core hoses but definitly miss that small one... was a pain to get to the bottom half. i was lucky enough to be doing my clutch at the time so had no trans to deal with. thinking royal pain to get to otherwise
Offline megaton
  • 87
Re: antifreeze leak
« Reply #6 on: March 27, 2012, 02:46:01 PM »
I replaced the small carburetor hoses about a year ago and now it looks like one of the bigger heater hoses -- the one closest to the block -- is now leaking. It looks like a bear to get at. I can't even see where it connects to the block. Any hints as to the best way to go about replacing it? What sized is the hose? I need to limp it to NAPA or somewhere to get the hose.
