Cherry Bomb
  • 124 Replies
  • 48536 Views
Re: Cherry Bomb
« Reply #75 on: April 14, 2011, 03:47:20 PM »
Got all the gauges mounted in the plate and hooked up today. As you see I still have a little trimming to do on the plastic trim. I had to quit to make dinner..... :P
Offline inchaos10
  • 162
Re: Cherry Bomb
« Reply #76 on: April 16, 2011, 07:28:12 AM »
I just bought these same gauges. Where did you plug the water temp sensor into.?
Re: Cherry Bomb
« Reply #77 on: April 16, 2011, 06:34:23 PM »
I bought the elecrtic versions. The thread on the engine is BSPT, not metric or ASPT. I had to buy adapters, but used the stock location for the sensor. I could not find a mechanical sender that would fit.
Offline inchaos10
  • 162
Re: Cherry Bomb
« Reply #78 on: April 17, 2011, 09:55:27 AM »
thanks. I guess im going to need to get a electric one too.
Re: Cherry Bomb
« Reply #79 on: April 22, 2011, 05:46:12 PM »
Remember, the gauges themselves are different from electric to mechanical. You can't just put a electric sender in there. I found all mine on E-bay for less than $200.00 including senders.
Offline djlantis57
  • 871
  • Take your chrome home
Re: Cherry Bomb
« Reply #80 on: April 26, 2011, 02:38:06 PM »
So do you drive with your head tilted to the right, or what?
 :laugh:
But seriously though a job well done
« Last Edit: April 26, 2011, 02:40:18 PM by djlantis57 »
Re: Cherry Bomb
« Reply #81 on: April 26, 2011, 07:47:09 PM »
It is easier to see a 90* angle when you glance down that quick rather than a 60* angle. Trust me you have very little time to look.
Offline Jluck
  • 1389
  • 40
Re: Cherry Bomb
« Reply #82 on: April 26, 2011, 08:11:43 PM »
That's an age old trick with old-school hot rodders and drag racers. If that tach needle is straight up 'you best be looking for another gear!
Re: Cherry Bomb
« Reply #83 on: April 26, 2011, 08:18:19 PM »
Thought I would mention Kreation Fabrication in Salem is doing the cage. I have known Bob for many years. They build sand car chassis and he does beautifull work.   :-[
Did you see it there today? I have been trying to get down there and get some work done but been too busy at work. Hoping for Saturday. You gonna be there this weekend Bob?
Re: Cherry Bomb
« Reply #84 on: April 26, 2011, 08:39:46 PM »
Ya, it's a good easy way to check all the gauges at a glance, needles all at 12 O,clock and your good
Offline djlantis57
  • 871
Re: Cherry Bomb
« Reply #85 on: April 27, 2011, 12:54:37 AM »
Hmmm now that makes sense. At first I just figured he had placed them in there temporarily to test fit. Didn't realize they stay that way. All pointed up is a really smart idea.
Re: Cherry Bomb
« Reply #86 on: April 27, 2011, 09:09:34 AM »
Stock cars and others do this, you never need to look at the numbers on the gauges
unless one is not at 12, then you give it a look to see if you are smoking an engine
Offline kreator
  • 634
  • 15
Re: Cherry Bomb
« Reply #87 on: April 27, 2011, 09:59:21 AM »
 :) Yes come down saturday and we will mount the fuel tank.  ;D
Re: Cherry Bomb
« Reply #88 on: April 29, 2011, 06:47:20 AM »
Sweet, how early you gonna be there? I wake up pretty early anymore.
Offline kreator
  • 634
  • 15
Re: Cherry Bomb
« Reply #89 on: April 29, 2011, 01:34:50 PM »
 :) :D ;D I'll be there by 830  >:D
