There is a hole in the side of the tranny, has a 3/8" square in it, use a ratchet
to remove it and stick your finger inside and down to check the oil level, if
there isn't any on your finger, add until oil flows out of the hole and replace
the plug. If you run the trans too low on oil you risk burning up the bearings,
gears and syncros so check it before you go wheeling of even driving around
