105 amp alternator upgrade - worth it?
  • 15 Replies
  • 14769 Views
Offline crewcabrob
  • 348
Re: 105 amp alternator upgrade - worth it?
« Reply #15 on: October 05, 2012, 08:31:55 AM »
I did that with mine, I put in the new DOT approved headlights from Truck-Lites.  They only draw a few amps even when on hi.  I also opted to go with LED aftermarket/AUX lights from PIAA.  Once again, they only draw a few amps when running.
I'm also pulling out the radio.  I'm not sure what I'm going to do for music yet, but I may just run a bluetooth connection to a couple of speakers in the stock location and use my phone or tablet as a music source.  I'm also going to fo through and swap out as many bulbs in the Sami as possible to LEDs.  There wont be many since the bumpers I have selected come with new lights built in and they eliminate all of the stock lights.
I will add a winch some time next year, but the infrequent use of it will really not nessicitate a larger alternator, just a larger battery for reserve.
I don't have AC in mine, but the blower motor for the heater does pull some good amps on start up.  I can't do much about that other than not use it.  I do have plans for on-board air, but by eliminating and carefully selecting other parts, I think it's doable on the stock set up.
Rob
