Some pictures from the last weekend. We ran into a small problem with the paint not setting up properly forcing us to loose a day on the cage installation, but BRD HNTR was able to get the rest of it installed this week.
Pictures of the front hoop before installation:
And the rear cage install. The cage was mounted by cutting holes in the floor then building a table for the for the tubing to mount to on the frame. This allowed us to run the cross bar to a flat surface along side the main rear hoop. We will be frame mounted in 4 points, with the option of adding an additional 2 points in the rear if we require a 6 point frame mount.
A quick shot of the finished front cage in the vehicle:
Full size pictures are being migrated to
http://picasaweb.google.com/CrawlersNW/RaceCar so you can check there for larger pics and for additional photos.
Main job for this weekend is the dash installation and to finish up the wiring.
