lug patern
  • 1982 Views
Offline badcat
lug patern
« on: January 28, 2010, 06:52:01 PM »
can anyone tell me what all lug paterns will interchange   with the geo tracker
also do you think '31's will work with just "2 body lift only?        Thanks in advance
« Last Edit: January 28, 2010, 07:02:25 PM by badcat »
just starting out offroading
Re: lug patern
« Reply #1 on: January 28, 2010, 07:06:45 PM »
5 on 5.5, same as the Samurai.  You can use old Ford, Dodge and Jeep CJ rims.  Some of the Dodge's do not have a large enough center hole and would need to be bored out.
31 could fit with some trimming and banging of the body.  I would throw on a 2" spacer lift from Jeff as well.
Offline badcat
Re: lug patern
« Reply #2 on: January 28, 2010, 07:45:24 PM »
thanks for info i'm new to offroading i'v seen those suspention spacers if he's the one that has then on ebay
may buy a set later but i'm on small budget i did a home made body lift
« Last Edit: January 30, 2010, 04:53:10 PM by badcat »
Re: lug patern
« Reply #3 on: January 28, 2010, 08:19:26 PM »
Wish I had a maid to build body lifts  ;)
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: lug patern
« Reply #4 on: January 30, 2010, 11:14:35 AM »
My maid cleans the house   i can"t get the maid to work on my trucklets   lol
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: lug patern
« Reply #5 on: February 05, 2010, 08:06:18 PM »
I went Wednesdayday and picked up my new springs. I am putting 4 door springs under my 2 door along with the 2" strut and spring spacers. This should give me a total of 3-3.5 inches of lift.
Tire Lug pattern s/b 5.5 or 5 X139.7 and here is what I have found to fit so far.....
98 - on Tracker
05 - on Dodge Dakota
04 - on Dodge Durango
94 - 97 Dodge Ram
66 - on Ford Bronco
54 - 97 Ford Truck
03 - on Kia Sorento
94 - 02 Kia Sportage
Suzuki
89 - 97 Sidekick
96 - 98 X90
01 - on XL7
98 - on Vitara
99 - on Grand Vitara
Another option is to reverse the Suzuki rim. (mount with valve stems in) The offset pushes the tires further out. Valve stem holes can be welded shut and a new hole re-drilled.
I am going to use 85 factory Ford aluminium rims and have purchased on Craigslist BFG tires .
Hope some of this info helps! Tux...
« Last Edit: February 05, 2010, 08:22:00 PM by tuxblacray »
Offline badcat
Re: lug patern
« Reply #6 on: February 06, 2010, 08:21:50 AM »
thanks for info
