Looking into getting a Samurai
  • 1496 Views
« on: January 25, 2010, 09:42:36 AM »
Hi, I'm looking into possibly getting a Samurai to do some offroading in.  And I've found one I'm relatively interested in, but I have a few questions.  I'm more of an ATVing guy, and I'm not quite as knowledgable in the offroad truck area.
So I'm looking at this Samurai (don't go snatching it on me now!!) and I'm most concerned about the 5.13 gearing.  With that kind of gearing, is there any chance of this being street legal/capable?
If it is a pure bread rock crawler, how hard is it to swap out for some more multi-use gearing?
Thanks.
Offline my996duc1
  • 222
Re: Looking into getting a Samurai
« Reply #1 on: January 25, 2010, 03:22:26 PM »
My 1987 tintop has the hybrid rear axle with 5.12 gearing, stock t-case, and 31" tires.
I am pulling about 4000 rpm at about 65 mph pn the freeway. No problems at all. Some people say it is too high of rpm and others claim they run them all day long at that rpm.... I had thoughts of changing gearing but the only other option for me with the hybrid rear axle is 4.62 gearing which I don't feel is enough difference to warrant the work of changing it out.
I will actually go ahead and do the t-case gears and gear this down more once I move away from CA and these higher speed roadways.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #2 on: January 25, 2010, 03:43:49 PM »
Cool, thanks a lot man.
Offline my996duc1
  • 222
« Reply #3 on: January 26, 2010, 11:43:41 AM »
no problem.
alot of good information and helpful people out here on the different samurai forums. I usually post the same question on a couple different forums and it varies which forum will hit and get alot of answers and you will also get alot of different answers.
Forums : zukiworld, zuwharrie, zukikrawlers
also check out : ack's faq, izook (both have good info)
Good Luck !
