The crankshaft pulley is heavy for a reason, its designed to damp out secondary (maybe higher order) vibrations on the crankshaft, this is why its often referred to as the harmonic balancer. You can get lighter crankshaft pulleys, these are normally underdrive pulleys which rotate the accessories slower. You can gain a few bhp but the trade off is reduced engine life and less effective charging at lower rpm.
