front bar
  • 1399 Views
Offline WDSBTR
  • 27
front bar
« on: January 22, 2010, 07:16:35 AM »
 tore off my front clip for a little more clearance. the front pipe that runs in front with the a arms is starting to crack and rust out. i have a PC of 2in square stock that is exactly the length under that bar. if i put this in as a support  do you guys think this would work instead of cutting and replacing the pipe ??????
Re: front bar
« Reply #1 on: January 22, 2010, 10:13:42 AM »
Ya, it should, but what about the rust? If you don't
stop it now, it will keep eating your frame.
I had that tube crack and break leaving me with little
steering control out at the Hammers in Johnson Valley,
so take care of the problem before it breaks thru
