All Here?
  • 2100 Views
Offline JTodd
All Here?
« on: January 20, 2010, 06:07:16 PM »
K...  Been collecting parts for a while looking to build a deer lease truck for the east Texas gumbo and and few trails and parks around here.. Not a zuki pro by any means so I wanna throw out the list of what I have and what my plans are for review / criticism:
I have:
'87 Tintop - Straight Body - Rod knocking in the 1.3 and tranny is whining like mad..
1.6L from a Tracker (~75k miles)
Freshly Rebuilt Tranny
3.73 Front and Rear Thirds with Lockrights
a set of 6.4:1 Tranny gears
Harley D 40mm CV Carb
Petro-Works 1.6L Swap Kit
2" lift shackles
New Spring Pads for SPOA
Z-link Steering Link
New Luk Clutch
Twin-Stick Shifter for T-Case
1" Driveshaft Spacers
I need:
Adaption for Harley Carb to Intake
T-Case Mounting Upgrades
Front Knuckle rebuilds
Rear Axle Bearings and Seals
Electric Fuel Pump
"Jeep" Style Bypass Filter
Fuel Regulator
I am planning to purchase:
My-Side (Knocks out carb adaption / fuel regulator)
GM Alternator Mounting Brackets and 100amp alt
8500lb Winch
I will be removing a fully functional AC system from the truck. This is a winter use vehicle primarily and I want to keep it as simple as possible under the hood..
I am pretty competent at metal fab and will be doing the SPOA (fully boxed and Trussed) as well as fabbing front and rear bumpers, a roof rack, rear seat, and some other stuff for the little guy.. Winch is a must for pulling up stands, lowering feeders, undoing bad judgments, etc..
What am I missing here?...
Plan is to be able to turn a set of Gateway 32.7 x 8.5 Buckshots in the gumbo here in deep east TX.. Am I headed in the right direction here?
Re: All Here?
« Reply #1 on: January 20, 2010, 06:15:05 PM »
I would look at adding a traction bar in the back as well.  If your turning larger meats with a SPOA you increase your chance of wrapping that rear axle up.  Especially with the increase in HP.
Is your 1.6 an 8 valve or a 16v?  If it is the latter you need a computer, if it is the former you are in good shape.
Looks like a solid build.  Keep us updated as you go along!
Re: All Here?
« Reply #2 on: January 20, 2010, 06:18:38 PM »
Convert the AC to on board air
Re: All Here?
« Reply #3 on: January 20, 2010, 07:39:28 PM »
~33x8.5 tires are kind of skinny for gumbo mud, I would think
a wider tire will help you float on the mud instead of digging in
and getting to the bottom.
I'm not a mud guy, hate getting out and digging out when I get stuck,
and the last time I got stuck was in liquefaction sand in a wash not far from
here, good thing a friend was with me or I'd of been walking for tools.
went from the surface to the bumper in less than 1 second, the front
tires bumped thru, felt like I hit a big rock, the back went to the bumper.
That was running 235 75 15 "mud" tires, which tread I now look at more
of an A/T tread.
Offline JTodd
Re: All Here?
« Reply #4 on: January 21, 2010, 09:20:40 AM »
the 1.6 is an 8v..  Trac bar is a good idea..
Offline zukimoo
  • 330
Re: All Here?
« Reply #5 on: January 26, 2010, 07:50:02 PM »
since your build looks like it's heading into the right direction I'd go with a crossover steering and skip the z-bar. I don't like the shackles but if you adjust the angles on the front then it'll be good. Keep the front steering angles stock.
06 Baja Buggy
Offline yzf438
  • 94
Re: All Here?
« Reply #6 on: February 01, 2010, 07:10:42 PM »
don't use the z link unless u gusset it good.  mine has turned into a U link before.  I know some of them come with gussets build in. mine didn't.
Offline Dimitros
  • 75
Re: All Here?
« Reply #7 on: February 01, 2010, 10:40:33 PM »
Despite the 1.6 is a noticeable power&torque upgrade I would rather think about header and exhaust build up. Also I dream about those tires but in 31x7.6-15 size.
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
