sammy axles on a 2 door sidekick? any comments?
  • 2704 Views
Offline cwymer
  • 33
« on: January 19, 2010, 06:46:39 PM »
i just found a set of sammy axles out in the hills.  they seem like they are in ok shape.  my question is, are they narrower than my sidekick axles?  obviously the kick has ifs but i plan to do a sas.  when i found the axles in the hills i had an idea.(the whole lightbulb thing)  would it work?
89 sidekick 2.5" body lift coil spacers up front running on 31X10.50's.  Custom push bar up front.
Re: sammy axles on a 2 door sidekick? any comments?
« Reply #1 on: January 20, 2010, 09:48:32 AM »
Yes, the axles are 2" narrower over-all, or 1" on each side.  You can fix this by installing some wheel spacers to even it out.  I think there are a couple of people who have done the SJ front axle swap if you search around the board.
« Reply #2 on: January 21, 2010, 01:15:37 PM »
Also, remember the samurai axles will have 3.73 gears.  Your trackick probably has either 4.62 or 5.12 gears.  So you will be geared really high with 3.73s.
Offline cwymer
  • 33
« Reply #3 on: January 21, 2010, 01:53:40 PM »
Ya. If do the swap I will put the kicker 3rd members in the Sammy axles
« Reply #4 on: January 21, 2010, 01:56:28 PM »
Uhh, no you won't.  The front one will fit, but the rear one won't.
« Reply #5 on: January 21, 2010, 04:31:37 PM »
I think he is looking at just swapping the front axle in.  If you are doing front and rear you will probably want to slip a Sammy T-Case in as well in order to get the rear axle off-set done correctly.
« Reply #6 on: January 21, 2010, 05:27:24 PM »
Could be, but I didn't read it that way...since he said...
So I took it as he was swapping both in.
Offline cwymer
  • 33
« Reply #7 on: January 21, 2010, 08:35:26 PM »
Sorry I meant axle.   The rear would be a hassle and its not worth it.  The sidekick rear is a stronger axle any way.
« Last Edit: January 21, 2010, 08:38:07 PM by cwymer »
